Group: DynoMotion Message: 8096 From: eypisa Date: 8/15/2013
Subject: KStep is not multiplexing inputs
I am building a CNC using KFlop+KStep and Mach3 software, the problem I have is that inputs are not recognized. I was reading other posts and found out that problem could be related to KStepPresent = TRUE instruction, but I'm using the "InitKStep4Axis" file and it already has this line.
I was checking Outputs/Inputs states in Kmotion Digital I/O and outputs #1,#2 works fine, but inputs are readed as ENC2, ENC3 signals not the Virtual/KStep signals.
Can you tell me how to tell in Kmotion that a Kstep is present, or if I missing something on the Mach3 setup?
Thaks and best regards,
Genaro.
Group: DynoMotion Message: 8097 From: Tom Kerekes Date: 8/15/2013
Subject: Re: KStep is not multiplexing inputs
Hi Genaro,
The 16 KSTEP inputs are multiplexed into KSTEP 4 bits at a time.  KFLOP IO bits 2 and 3 are the multiplexor outputs.  IO bits 4-7 are the multiplexor inputs.  Are Bits 2 and 3 set as outputs and toggling on and off on the Digital IO screen?
Please check this after powering up KFLOP, then executing the C program InitKStep4Axis.c, but before running Mach3.
What Version are you running?
Group: DynoMotion Message: 8109 From: eypisa Date: 8/16/2013
- I am using version 4.30 build 12:02:08 Mar 3 2012.
- On Mach3 "Config Plugin" tab shows Dynomotion-V4.30.
- After powering up bits 3 to 7 are on.
- After executing "InitKStep4Axis" bits 2 and 3 are toggling.
Inputs are working fine in Kmotion after executing "InitKStep4Axis" all of them has been read OK in Virtual/KStep but still not working on Mach3.
MACH3 OUTPUT CONFIGURATION:
- Output #1: Port#=1 PinNumber= 0.
- Output #2: Port#=1 PinNumber= 1.
* Pressing Spindle toggle button: Relay #1 just goes ON for a second then goes OFF, Relay #2 goes ON right after #1 goes OFF.
* Pressing Flood or Mist button: Relay #1 goes ON and keeps ON until button is pressed again.
MACH3 INPUT CONFIGURATION:
Plugin manual tells if input pin number is greater than 128 use Port#2 and substract 128 pin number so I am configuring:
- EStop (Pin 168): Port#=2 PinNumber= 40.
- THC ON (Pin 169): Port#=2 PinNUmber= 41.
- THC UP (Pin 170): Port#=2 PinNUmber= 42.
- THC Down(Pin 171): Port#=2 PinNUmber= 43.
Mach3 Diagnostics Screen shows no activity when input is activated. Actually I ran Kmotion when Mach3 still running and Virtual/KStep reads inputs OK.
Can you tell me what I'm missing,I really apreciate your help.
Best regards,
Genaro.
> Hi Genaro,
> From: eypisa <energiainteligente.sa@...>
> Sent: Thursday, August 15, 2013 8:39 AM
> Subject: [DynoMotion] KStep is not multiplexing inputs
> Hi Tom,
> Genaro.
Group: DynoMotion Message: 8110 From: Tom Kerekes Date: 8/16/2013
Hi Genaro,
There was a bug in the Mach3 Plugin regarding Input numbers greater than 127.  Please try the latest test version to see if it fixes the problem:
http://dynomotion.com/Software/KMotion431i.exe
This Version also supports accessing Virtual IO bits 1025 - 1151 using port 3
Group: DynoMotion Message: 8111 From: eypisa Date: 8/16/2013
Do I have to unistall KMotion old version and Mach3 before installing new version?
> Hi Genaro,
> Sent: Friday, August 16, 2013 8:56 AM
> Subject: [DynoMotion] Re: KStep is not multiplexing inputs
> Hi Tom,
> Best regards,
> Genaro.
> > Hi Genaro,
> > From: eypisa <energiainteligente.sa@>
> > Hi Tom,
> > Genaro.
Group: DynoMotion Message: 8112 From: Tom Kerekes Date: 8/16/2013
Hi Genaro,
No.  The last step in the KMotion Installation links Mach3 to use the last installed KMotion code.
You will need to Flash the new firmware into KFLOP using:
KMotion.exe | Config/Flash | New Version
Also copy the files in the \KMotion\Data directory to the new Version.
Group: DynoMotion Message: 8114 From: eypisa Date: 8/16/2013
You are a genius, inputs reading are working fine in new version. Do you have any idea why Output#1 and Output#2 are not working as expected?
Thanks for your help,
Genaro.
> Hi Genaro,
> HTH
> Sent: Friday, August 16, 2013 10:59 AM
> > Hi Genaro,
> > Hi Tom,
> > Best regards,
> > Genaro.
> > > Hi Genaro,
> > > Regards
> > > Hi Tom,
> > > Genaro.
Group: DynoMotion Message: 8117 From: Tom Kerekes Date: 8/18/2013
Hi Genero,
Sounds like you may have the same Mach3 Outputs configured to multiple things like Spindle CW, CCW, Flood, etc...
How do you have things configured?
Group: DynoMotion Message: 8125 From: eypisa Date: 8/19/2013
I think hardware connectios are OK because Relays works fine on KMotion.
I used this config the first time I tried on Mach3 and it doesn't worked:
*Output #1 Port#1 Pin#1
*Output #2 Port#1 Pin#2
SPINDLE SETUP:
*Clockwise (M3)= Output#1
*CCW (M4) = Output#1.
*Mist (M7) = Output#2
*Flood (M8) = Output#2
The second time I disable Mist and Flood function, and used this configuration (it doesn't worked neither):
*Output #2 Disabled
SPINDLE SETUP:
*Clockwise (M3)= Output#1.
*Mist (M7) = Disabled.
*Flood (M8) = Disabled.
Then I tried different Port# and different Pin# and is always same results: everytime that I click Spindle toggle button or when program calls "M3" the Relay #2 turns ON and "M5" turns OFF.
Right now I am using second configuration connecting plasma trigger on Relay#2, but I don't know if this problem affects THC because is not working neither.
Mach3 is reading THCOn, THCUp and THCDown signals but Z axis is not moving.
I am reading all posts with similar problems and tried different solutions but still not working.
Any help or hint will be really apreciated.
Genaro.
> Hi Genero,
> Sent: Friday, August 16, 2013 12:09 PM
> Tom,
> Genaro.
> > Hi Genaro,
> > HTH
> > > Hi Genaro,
> > > Regards
> > > Hi Tom,
> > > Best regards,
> > > Genaro.
> > > > Hi Genaro,
> > > > The 16 KSTEP inputs are multiplexed into KSTEP 4 bits at a time.ÃÆ'‚  KFLOP IO bits 2 and 3 are the multiplexor outputs.ÃÆ'‚  IO bits 4-7 are the multiplexor inputs.ÃÆ'‚  Are Bits 2 and 3 set as outputs and toggling on and off on the Digital IO screen?
> > > > Regards
> > > > TK
> > > > ÃÆ'‚
> > > > Hi Tom,
> > > > Genaro.
Group: DynoMotion Message: 8128 From: Tom Kerekes Date: 8/19/2013
Hi Genaro,
I can't think of why.  But I find some things confusing:
Why use IO 1 and 2?  For KSTEP the Relay Output IO's should be 0 and 1
What is Relay #2? - KSTEP has 2 relay drivers called Relay #0  and Relay #1
What do you mean by : "M5 turns off" ?
Maybe attach/post your Mach3 XML file so we can test it.
THC Up/Down must be handled by KFLOP not Mach3.  Mach3 no longer does real-time control when used with KFLOP.  There are some Yahoo Group Posts that discuss this and some example C programs for THC.
Group: DynoMotion Message: 8129 From: eypisa Date: 8/20/2013
     My apologies of not being clear on my questions ( I am probably going crazy).
 > What is Relay #2? - KSTEP has 2 relay drivers called Relay #0  and Relay #1
      - You are right, my mistake when wrote Relay#1 and Relay#2.
 > What do you mean by : "M5 turns off" ?
       - When I click Spindle toggle button or entry "M3" on MDI screen:
            * Relay0 just turned ON for a second then goes OFF.
            * Relay1 turned ON right after Relay0 goes OFF.
       - When I click Spindle toggle button againg or entry "M5" on MDI screen:
            * Relay1 turns OFF.
      I am sending you the XML file by email because I cannot find the option to attach it on this post.
      I am reading other posts about THC control with KFlop, I will probably start a new topic when ready to make questions.
Genaro.
> Hi Genaro,
> From: eypisa energiainteligente.sa@...
> Sent: Monday, August 19, 2013 3:00 PM
> Hi Tom,
> SPINDLE SETUP:
> *Output #2 Disabled
> SPINDLE SETUP:
> Thanks,
> Genaro.
> --- In DynoMotion@yahoogroups.com, Tom Kerekes tk@ wrote:
> > Hi Genero,
> > Tom,
> > Genaro.
> > > Hi Genaro,
> > > HTH
> > > Regards
> > > From: eypisa
> > > > Hi Genaro,
> > > > There was a bug in the Mach3 Plugin regarding Input numbers greater than 127.ÃÆ'‚  Please try the latest test version to see if it fixes the problem:
> > > > Regards
> > > > TK
> > > > From: eypisa
> > > > ÃÆ'‚
> > > > Hi Tom,
> > > > Best regards,
> > > > Genaro.
> > > > > Hi Genaro,
> > > > > The 16 KSTEP inputs are multiplexed into KSTEP 4 bits at a time.ÃÆ'Æ'‚ÃÆ'‚  KFLOP IO bits 2 and 3 are the multiplexor outputs.ÃÆ'Æ'‚ÃÆ'‚  IO bits 4-7 are the multiplexor inputs.ÃÆ'Æ'‚ÃÆ'‚  Are Bits 2 and 3 set as outputs and toggling on and off on the Digital IO screen?
> > > > > Regards
> > > > > TK
> > > > > From: eypisa
> > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > Hi Tom,
> > > > > Genaro.
Group: DynoMotion Message: 8130 From: Tom Kerekes Date: 8/20/2013
Hi Genaro,
Your Mach3 XML has both a Spindle C program configured to control the Spindle and Mach3 Outputs Configured to control the Spindle.  You can use one or the other but not both.
Delete the C Program Specified in Mach3 | Config | Config Plugins | Dynomotion | Spindle Speed User Program
Also because Step/Dir is generated by KFLOP set the Port and Pin Outputs to Port 0
The THC inputs will be handled by KFLOP so do not enable them in Mach3
Group: DynoMotion Message: 8134 From: eypisa Date: 8/20/2013
Amigo Tom,
You are right as usual, outputs are working OK now, I am going to start working on the THC configuration, is there any topic or post you recommend me to read?
I really apreciate your help, Iron Man used to be my #1 hero but I think you are my #1 Hero now.
Greetings from Tijuana Mexico,
Genaro.
> Hi Genaro,
> HTH
> Sent: Tuesday, August 20, 2013 8:06 AM
> Hi Tom,
>      My
> : "M5 turns off" ?
> screen:
> MDI screen:
>       * Relay1 turns OFF.
> Genaro.
> > Hi Genaro,
> > Hi Tom,
> > SPINDLE SETUP:
> > *Output #2 Disabled
> > SPINDLE SETUP:
> > Thanks,
> > Genaro.
> > > Hi Genero,
> > > Regards
> > > Tom,
> > > Genaro.
> > > > Hi Genaro,
> > > > No.ÃÆ'‚  The last step in the KMotion Installation links Mach3 to use the last installed KMotion code.
> > > > HTH
> > > > Regards
> > > > TK
> > > > From: eypisa
> > > > ÃÆ'‚
> > > > > Hi Genaro,
> > > > > There was a bug in the Mach3 Plugin regarding Input numbers greater than 127.ÃÆ'Æ'‚ÃÆ'‚  Please try the latest test version to see if it fixes the problem:
> > > > > Regards
> > > > > TK
> > > > > From: eypisa
> > > > > ÃÆ'Æ'‚ÃÆ'‚
> > > > > Hi Tom,
> > > > > Best regards,
> > > > > Genaro.
> > > > > > Hi Genaro,
> > > > > > The 16 KSTEP inputs are multiplexed into KSTEP 4 bits at a time.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚  KFLOP IO bits 2 and 3 are the multiplexor outputs.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚  IO bits 4-7 are the multiplexor inputs.ÃÆ'Æ'Æ'ÃÆ'¢â‚¬Å¡ÃÆ'Æ'‚ÃÆ'‚  Are Bits 2 and 3 set as outputs and toggling on and off on the Digital IO screen?
> > > > > > Regards
> > > > > > TK
> > > > > > From: eypisa
> > > > > > Hi Tom,
> > > > > > Genaro.
